Large Coordinates
Hello
(09:48:46) The part “Planar Light” contains very large coordinates (nan)… How can i solve this problem. Some objects give this error when i use planar light. Thank you
@linear.aydınlatma Heyo welcome! I’m unable to replicate this, can you share any more information?
  • Did you use the Edit Menu “Add Light”?
  • Or did you assign the planer material to geometry like a plane?
  • Are you in GPU or CPU mode? Product or Interior mode? Does changing modes make a difference?
  • Does saving and reopening the file fix it?
  • Are there light materials or geometry with the same names?
Thanks for your reply.
-Yes, i use Edit Menu ‘Add Light’
-I use GPU Mode and Product mode
-i try but it doesn’t fix it
-Actually i never check the names.
As i told you not all object but some object gave this error.
